I have a gas Baxi boiler to radiators and a gravity-fed HW. The HW circuit to cylinder has a motorised valve controlled by a timer.
I have part-drained the system (using drain valve at bottom rad) to change a leaking TRV upstairs, tying-up the ball-valve in the header tank first. Then refilled. I drained the system into a large plastic water carrier and, when refilling, bled radiators in turn.
All is working well, except:
1 - I found that not all of the water will fit back into the header tank now. About 3 to 5 litres remains. There is no air in the radiators at all. I have just rechecked.
2 - the hot water (in the cylinder) is taking longer than usual to reach temperature.
The only thing i can think of is that there might be an air lock in the HW heating circuit. (I did, maybe, have the motorised valve closed when refilling. But wouldn't this just escape when the valve was open?
I could drain the HW heating circuit down by the boiler?
Any advice please, so i'm not on my own?
nomsmithy
nomsmithy
