Air lock in a diesel engine
31 Jan 2005
Fife
Can anyone help??
I posted earlier today about problems staring my Fiat Scudo, I have just spoken to the guy I bought it from who said it was quite low on diesel, is it possible that there could be some sort of air lock in the fuel pipe as when I try to start it, it turns over, catches then dies as if it is starved of fuel.
Is there a way of bleeding the fuel system?
V
Low fuel should'nt cause an airlock unless theres some other problem, anyway as far as I know if you can loosen a injector pipe were it connects to a injector and crank the engine air should escape from there,but dont loosen to much so pipe comes off.
dont start new threads about teh same thing, post in your existing thread.
