I have an oil-fired boiler (Camray 2, old but working well) which serves an indirect hot water system and central heating.
The heating is not at the moment just the hot water.The hot water system also serves two towel rails.One is turned off.
when the boiler is on the pipe going to the other towel rail gets scalding hot but the towel rail stays cold (no air when bleed key used). After about 30 mins there is a huge rushing sound for about a minute and the towel rail begins to heat up. During this bit the pipe going to the rail cools down briefly. In another five minutes the noise starts again and lasts two minutes and the towel rail gets hotter. After another five minutes the noise starts again. It's then time for the boiler to switch off.
I went into the loft this morning to see if anything was wrong there. It wasn't but when these noises were going on there was almighty coughing out of the vent pipe into the header tank, so much so that the (very hot)water splashed all over the place.
This problem started a little while ago and I hoped it would solve itself (we had the heating on for a while to see if the pump would clear it but it won't). It seems air is getting in somewhere but I can't see where - there don't appear to be any leaks and the radiators all get hot eventually.
One further thing. Even though the heating is off the upstairs radiators are warming up via the heating pipes unless individually switched off. There is no check valve to stop this happening but I don't remember it happening before the noise problem started.
If anyone can shed any light I'd be very grateful - sorry for going on a bit
