I live in a bungalow, and if someone is running hot water from the bath tap and I run the hot water in the kitchen at the same time, this causes an air lock. From this point forward, the hot water from the tap in the kitchen just trickles out. I have tried to run the kitchen tap whilst turning the bath tap on / off, this makes the kitchen tap splutter but doesn't restore full flow. Last time, it took about a month and eventually sorted itself out.
First, any ideas how I can clear the air lock? There is a mixer tap in the kitchen so it would be hard to fit something to it to blow the air out. Second, how do I stop this happening again (apart from the obvious which is don't run both taps at the same time!)
Thanks.
Jeremy
Thanks.
Jeremy
