Hi all,
I removed a downstairs radiator to drain some of the system volume so I could run a sludge remover/cleaning solution through for a couple of days prior to getting a new boiler fitted. I currently have an open system with gravity hot water.
Now I can't seem to get the heating system to circulate and can't bleed all of the radiators (I got some air out, but then no water or air). The pump is running and the water seems to be cold directly above it although I've tried undoing the bleed screw and I'm getting water coming out.
After searching on here it would suggest an air lock or a blocked cold feed. The problem is that the cold feed is connected to the hot water return to the boiler from the cylinder and the hot water is fine so it would seem like an air lock. As the water feels like it isn't circulating above the pump, is shutting off other rad valves likely to work?
Just wondering if anyone can offer any advice?
Thanks in advance!
Thanks in advance!
