hi...
at friends house
floor standing boiler, ch pump and programmer, hw cylinder in the outhouse, pipework runs from outhouse into house above head height insulated in summit and away under the fllorboards
cwsc in the loft if main house , runs all the way to the shed to the hwc and back to taps !!!
the f and e is at head height in the loft (its more of a third floor than a loft) (yes...above the cwsc !)
on the same level, in the room next door is a rad. this rad is only 2 foot lower than the f and e. i cant tell yet how its fed but i suspect its been connected from the 1st floor up (a later addition ?)
i cant get it to bleed. i have had the rad valve off...nothing, yet mt friends say it use to work. (thay asked me to look at their ch, re lack of heat. it turns out to be a dry f and e , ballvalve problem.
any ideas on the top rad .
could the only 2 foot height diff be the problem.
could i cut the pipe tails and put in a drain valve and consequently fill it from a hose ?
at friends house
