Puzzled, could do with some other opinions please.
Shower is a Triton 'Altair' bar mixer type. Fed from conventional gravity supplies, cold from cistern in loft, hot via a Surrey flange on cylinder, both in 15mm to shower. Pipework drops, runs under floor then back up to shower.
If a bath is run (hot supply to bath is 22mm) then the hot supply to the shower seems to air lock. (Some hot water gets through, but at nowhere near the same rate as the cold.) Removing the shower head from the riser rail and leaving it dangling in the tray with shower temp control turned to full hot leads to a lot of gurgling and air being released from the shower head with the water, until eventually the gurgling ceases, the hot supply then achieves about the same rate as the cold. The shower temp control can then be set to mid way and a comfortable showering temp is achieved.
Have upgraded cold feed from cistern to cylinder to 28mm, fitted a single check valve in hot supply to shower and it's still air locking on the hot supply after a bath has been run. Running out of ideas, any advice gratefully received.
