Hi Guys,
I've got a new boiler and central heating system (about a year old) which may have a problem.
I had to remove the towel rail about 6 months ago to fit a new heating element as the old one had blown. I then did the following as instructed by the plumber:
re fitted the towel rail and filled it back up
filled the system back up to half way on the pressure gauge
bled the towel rail
filled the system back up to half way on the pressure gauge again
turned on the boiler for half an hour and let the system run
turned boiler off
bled the other rads
I then noticed some months later that the towel rail had become cold at the top quarter so i bled it again. Now the towel rail is cold at the top quater again and I know the system pressure goes up and down but its been contently below half way on the gauge for months.
The question is, does it sound like there's a slow leak or is this normal?
I've checked the shops below my flat and there's no sign of water leaking through.
Please let me know what you think.
bled the towel rail
turned boiler off
bled the other rads
