please explain the function of the air pressure switch - obviously it allows the fan to start so does not rely on pressure to run the fan but it changes state when it detects the fan running - is this correct? it then switches the fan off - yes?
the fan starts and makes the switch not the other way about
You are trying to insult me but this is obviously way above your heads - I am looking into the electronics of the PCB to find out the switching logic - need to learn a bit more than "its part of the ignition sequence" - maybe some of you change things until it works but a fault on a PCB will be a result of a single component that will cost pennies to replace.
Never mind, I'll figure it out!
who said hes done ccn1.ps just to confuse. most modern boilers dont have one.
