under NO circumstances can this vent be blocked UNTIL a gas engineer has confirmed it is safe to do so, what is written above is an assumption, based on adventitious ventilation entering the room, and there is no way of checking this over a computer
Why do you think this regulation is in place then kirk,you think someone just picked a number out of thin air?
It`s not an assumption,there`s always enough air entering a room to allow a 7kw or below flued space heater to be fitted and used(as long as it`s fitted and/or checked by a suitably qualified individual).
This figure was arrived at after the boffins at British Standards(I think) sealed a room as completely as possible and found this was the amount of adventitious air that still entered.
Other factors have to of coarse be taken into account,type of flue,flue pull etc and any sensible person as the OP seems to be would ask advice.
I should possibly have put more emphasis on getting an engineer in,but my answer was in essence correct and if this is the worst answer you`ve ever seen on here you obviously don`t come on very often.
