Airbrick to ducting
23 Jan 2023
Hello,
Is there a product that I cause use to connect a clay airbrick to rigid ducting? There’s is a cavity wall as well.
Need run ducting from existing air bricks on house through extension and into new extension brickwork.
You can remove the existing air brick, fit your duct pipe in the hole and mortar or foam it in.
At the other end, in your new cavity, you fit an adaptor from round to rectangular, and this goes onto a telescopic 'periscope' vent, which goes up through the cavity, and lines up with your new air brick.
