Hi all,
any advice on this much appreciated
Have just a combi boiler fitted and so had hot water cylinder removed from bathroom airing cupboard.
this leaves me with a bigger cupboard for storage (wahey) but a dark one..
Getting into the ceiling to run a new light is gonna be a real pain, so am thinking of simply replacing the old cylinder power point with a switched FCU, and fit that with a 3 amp fuse running 1.5mm twin and earth cable up to a single light fitting.
I would also run the old cable under floor, and position the switched fcu just inside the cupboard door as is more accessible (running old cylinder power point cable under floor and up)
Couple of questions >
Does this all sound ok, and am I right in thinking this is non notifiable as is not in a 'special location' ?
Would it be ok to use a standard switched fcu in this location or would it be best with a pull cord (if people go in there with wet hands looking for a towel etc..) ?
thanks in advance guys
