Hi guys, I appreciate any help you can give me.
I’m coating a whole room in one colour (sage green) hinc walls ceiling, coving and trim. I started but the sprayer put out too much paint, so now a 1m width of wall is painted and dry.
I stupidly used Zinser peel stop as a spot prime where the sanding had gone to the plaster. That looks like it’s showing through after a single coat.
- what order should I continue with the room. Not sure where I would start stop on the trigger.
- will the finish be different because I dint have a wet edge when I start to spray again?
- will a 600mm Wagner extension pole work with the Graco? The connector fits but no idea about compatibility.
hope you guys can help!
