Ive got a erbauer eaps600 ive used it twice and both times ive put way to much paint on the walls. Im sure i used a 517 tip. first i think the pressure was too high (max).
The second time was about half between the min and max setting. And still used way much paint. Might look into getting a pressure gauge for it so i can see what psi im using. Apart from the pressure any other ideas what could be making it spray out to much paint?
I was using dulux easycare if that info is any use
