Problem with airlocks
Could anyone help with the following problem regarding the cold feed from the loft tank to the toilet and sink in the bathroom
The original bath had 22mm runs of hot and cold water feed with 15mm branches off to toilet and washbasin.
The new bath has no taps as it is filled from the new shower unit, which is a combined
Shower and bath filler system with completely separate pumped feeds of hot and cold water.
The toilet and washbasin uses the original pipe modified to suit new units
The old feeds to the bath where capped off at the bath end, and the pipe still feeds the toilet
And washbasin, also the down stair cloakroom (toilet and basin) which has no problem they still work fine.
The problem is about every 3 - 4 weeks the supply to the washbasin in bathroom stops, which also stops the toilet from filling.
In order to get the system working again I disconnect cold tap tail from the 15mm feed and connect
A piece of pipe fixed to my wetvac and suck out till the water runs at full bore again, this always works
And it also gets the toilet working, but the problems back after a month.
The hot water supply works perfectly ok
The new tape at washbasin is a Axor Citterio single lever operation tap for hot and cold
The tails from the tap head are only 10mm dia giving about a 5mm hole for the water to pass
And the same for the toilet one inside the system.
I am wondering if the feed hole size is part of the problem and do they work well on gravity systems
On the other hand the hot feed to the same tap with same size hole has never stopped working since
Installed and the cylinder is on the same level.
