I'll try not to make this a lengthy initial post but have lots of information i can feed into it. (Please bear with the read...there may be some work for someone here)
So...
Bought a house as a bit of a do-up project after it had a flood.
House came with V old Gas boiler + open vented Rad system. BUT had an AirSourceHeatPump (ASHP) fitted + New mains pressure DHWT with 2 internal coils. 1 fed from ASHP + GAS boiler, other fed from new Thermal Solar panels.
All good?
WRONG.
I don't want to bad mouth the company (I do, but wont) but it was installed COMPLETELY incorrectly. I can expand on this greatly if needs be to justify the next stage. But with near £1000 electricity bill for a quarter when not living there was the first alarm bell.
I ripped every pipe and RAD out of the house, and have moved the water tank (Viessmann Vitocell 300B) down to the garage to be near the ASHP (Viessmann Vitocal 300A). There is also a buffer tank connected to the ASHP (Vitocell 100 or 200 or something).
Now i want to get it all connected up again.
I've been over various options back and forth and it all basically comes down to cost.
To get my heatpump back and running, assuming the heat destination of rads or UFH is already there, i've been quoted around 10k. This is just to plump everything in the garage, connect the solar etc (they used 15mm pipe before for the Solar connection to tank. Just wrong).
Coupled with around 10k for UFH upstairs and downstairs, to be ideal for the ASHP temps, is 20k to get a system up that i've not had to fork out for the dear bits (ASHP, Tanks, etc).
I just can't do it.
I can't go to standard rads to reduce cost due to low temps needed.
low temp rads for whole house come in around 8k (only looked at jega so far mind).
I've decided on UFH downstairs at around 5k regardless and i can fit that myself up until manifold and get plumber to do that.
So i've now started to look at maybe a decent Gas boiler so can use UFH downstairs and standard rads up stairs to save cost. I know you can reduce temp to UFH with mixing and then run the rads upstairs at 65/54 whatever the norm is.
This would be fine and i could plumb the internal rads myself and get plumber to connect all up which should'nt be near 10k! (IMNSHO)
UFH would be zoned with actuators etc and upstairs on TRV's.
That's all cool....BUT i really want to go down the Weather comp route that the ASHP deploys. From what i've read its the best savings.
We will be in this house for a LONG time so i want to get it right given the budget.
So question is is there a way to run mixed temp (i.e UFH downstairs + standard rads upstairs) AND still deploy weather comp?
Anyone got any recommendations on that route or am i going down the wrong path completely?
For anyone still at the end of this post. Thank you for your patience. I'm at a complete loss in what to do and have been bitten a) with the crap install in the first place and b) previously with tradesmen promising the earth but not knowing how to do it. (Not a reflection on all tradesmen whatsoever just personal experience).
I can't do the whole thing myself as i'm not a professional plumber by any shouts and dont know all the ins and outs and gizmo connectors or valve things required.
Any pointers?
So...
All good?
WRONG.
I just can't do it.
Any pointers?
