I have a Ventcroft Compact Classic bell with a CK 700L control panel.
If I remove the screw on the bell box which then activates the tamper microswitch the bell goes off and continues to ring, regardless of whether the panel is either unset or in engineering mode, is that correct and normal?
Is this purely the bell deciding to sound regardless of the control panel mode?
If so it seems a bit of a pain to service the bell box, eg change its internal battery, you have to put up with the sound until you open it and disconnect its internal battery?
Thanks!
Thanks!
