Thanks guys. So, to clarify so far: the alarm senor points have a 8 core cable back to a control box point with a mains cable to this point. The user control box is at the front door.
Two more Questions:
1. Will a 8 core cable be enough for the user control panel at the front door?
Yes most kepad use 5 - 6 wires
2. Will the user control panel have a main cable to it?
Yes fed from spur with 3a fuse non switched spur
3. A dummy alarm box with flashing light. Will this need a main cable and/or a 8 core alarm cable run to it?
Depends on dummy box, most are battery powered, but why not do what i do fit a second real siren so you have two sirens normally at fron and back and 6 core is enough, but i use 8 core.
thx
