Hi, got a wired alarm, all i know is the keypad has Accenta+ on it and the main box G4. Each zone seems to only have one sensor, i'd like to add maybe another PIR to the garage along with door contacts, can each zone have more than one sensor?
Yes. You just need to make sure that the main zone loop and tamper loops are wired in series through each sensor, and the power connections in parallel.
Thanks, although i guess i will need the alarm company out as i won't have the engineer reset code?(not checked the booklet yet!). The garage has one PIR, i was going to add 3 door contacts(double garage & side door) and maybe another PIR, any problems with that?
