Hi there,
We have a couple of alcoves in our lounge that have been crying out for a fitted storage solution, so I'm finally getting around planning some cupboards and 'floating' shelving.
I've got a good deal on some sheets of birch plywood (18mm) so it's my intention to build most of the cabinets and shelves from this.
The shelf battens will be pine (or whatever I can lay my hands on) with a solid wood piece making up the front, I'll probably tack some 4mm plywood to the upper shelves to hide the battens. Everything will be painted white.
The shelving I'm not too worried about as I've built and fitted a couple of sets of this type before, but this is my first time venturing into cabinet making and I want to run my current plans by some more experienced eyes and see what you think.
I have a pretty good idea of how I'll fit everything together - I'm planning on using pocket screws for the face frame, so I might make this section out of something other than plywood. I'd also like to make the doors as properly as I can, so again, these will probably be made from Poplar or similar.
The one area I'm lacking in confidence is the base of the cabinet. The plans above are just what I've thrown together but I'm very aware that I will need to adjust the height to level the unit as well as provide more support in the centre. What are people's thoughts on this? I've seen people use kitchen feet to help with the adjustment but others have suggested that building a dedicated plinth, attached to the floor, would be the way to go.
For reference this alcove is 980mm wide.
Thanks for taking the time to look at this!
