The main water feed as it arrives under my drive is in black poly (what I call Alkathene), marked S & L Polythene BS1972 Class C 1". (It is currently reduced down to 3/4" and gets blocked by debris at the point of reduction.) I need to extend into the house in 32 mm MDPE and also pick up a 3/4" Alkathene feed to the outhouses.
I intend to use Philmac Metric/Imperial fittings, a 32mm/1" coupler to join the Alkathene to the 32mm MDPE, then after a few feet of MDPE a Metric/Imperial tee 32mm/1" x 32mm/1" x 25mm/3/4" to connect to the 3/4" Alkathene. Then 32 mm MDPE into the house.
Before I rush in I have a few questions.
Is Met/Imp the correct range to use for the above?
Should I use Polygrip Plus for the MDPE connections in the house, or continue with Met/Imp?
How much degradation of the Alkathene can these fittings stand, and still be watertight? The main Alkathene pipe has been 'accessed' a few times before by previous owners, so is fairly scratched. Should I try to excavate further to find a more virginal section? (I'm not sure that one exists.) This is low pressure gravity fed supply.
Rgds.
Rgds.
