Hi
I had all my old dimmer switches replaced with Varilight soft touch dimmers. of different power handling models, and were working fine until quite recently.
Now all the sets of LV downlights that are controlled by the new Varilight dimmers continuously dims and brightens...the only way to control them is to switch off the light circuit at the consumer unit. The information sheet mentions that the dimmers safety mechanism comes into affect when the dimmer becomes overloaded by dimming the lights to the minimum level, but does not explain why the lights then brightens again..and so on.
The property in question is in a place with high humidity, could this be the cause?
If one dimmer switchis is overloaded, will this affect the other dimmer switches? Otherwise, why would all the other sets of downlights in the entire flat behave this way?
