All rads heating up when Hot water Tap is on?
23 Sep 2004
Hi
Heres the info
Ariston Euro combi SX20 MFFICE
The problem i`m getting is all my rads are heating up when the hotwater tap either in the kitchen or bathroom is switched on? not just getting warm but upto temp!
It never used to be like this so ive rulled out a couple of replys from reading the other forum post.
If anyone has the answer i would be gratefull.
Ta
:D
Yes the DV. It's on the right, back a bit. Microswitch(es) on top should get pressed (upwards) when you turn the hot water tap on. Probably just the diaphragm, which is in the big end. You can get just the bits from that end for a few quid. You need something like a mini right angled ratchet screwdriver on all 8 screws to change it.
I was leaning towards that just needed confirmation.
Whts the chance HRPC have the kit.....lmaoooo
no seriously they might??
Thanks for the replys. :D
