Alpha 24
28 Oct 2008
Birmingham
Hi all,
I have seemed to run into a problem with my boiler. When i turn the HW setting on there is no hot water in the shower, and when i set it to CH & HW it still does not work however if i set the timer between the times i need it on CH & HW the hot water works and the orange indicator remains continuous. If the hot water works when i set the timer on the boiler must be working however we can not keep the heating on between these times. Can anyone please help?
If the top orange light is on you need an RGI to check it over as it is a fan/safety device that is failing.
