Help please for a newbie on this forum.
For no obvious reason (boiler's been working fine for a good few years) the HW on this Alpha 240 combi will only fire up if CH has been running/heating for at least ten minutes. Otherwise, demanding HW brings up the relevant green light but doesn't ignite boiler, and in fact switches the whole boiler off if the CH demand has had it running for less thn 10 mins.
I have checked (removed, circuit-tested, replaced) the microswitches to the primary and DHW flow valves and both are working fine and I've even switched them over. Cables carefully reattached.
I've changed the DHW diaphragm (using kit - which included brass nut which forms the spindle for the pin). Also cleaned and replaced the primary flow diaphragm. (There was no visible wear/damage to either.)
Both the primary and DHW pins are moving freely. When heat/CH demanded they emerge easily far enough to operate the microswitch levers. The springs are strong (pins don't push back easily with a screwdriver).
Thus we have done (quite carefully, yesterday) all the easy checks/remedies recommended in earlier threads in this forum. What next - is it likely to be a problem in the diverter valve itself? Can that be tested before buying a new part (expensive)?
Many thanks in advance.
