Hello - not sure if this appropriate - multiple questions/issues in one post however this is my 1st post so here goes - and apologies for anything which is not clear or sounds stupid;
Make/model - Alpha 240E combi
1) Over the weekend I drained the CH, added cleaner, re-pressurised and left the systems fully on for many hours. Next day, drained and flushed with mains, via the filling loop and added inhibitor. Also took the opportunity to replace a leaking radiator value. The problem was this - after re-pressuring the system, ensuring all radiators where bleed correctly - except a towel rail in the bathroom which has no bleed point (!?) - and the pump in the boiler was bleed, the boiler refused to initially ignite. This happened both times following drainage.
The symptoms where;
a) Fan starts
b) Gas not released to burner, hence rest of ignition system halted
I am assuming that the gas not switched on due to something - air somewhere else in the boiler and therefore no water being pumped around? On both occasions, after a 30 to 40 minute period, of switching CH on (and DHW) and off, leaving the system on (for a few minutes - during which time boiler makes a whining noise), and leaving the system off, eventually life restored and no further problems.
My concern is, as the expectation that sometime I shall need to drain the system again, is there anything is I should be aware of to do/perform.
2) Second issue - there is a slight leak from the CH return isolation value (22mm connections), which has 2 inputs (return and filling line) and 1 output (boiler) - is this a standard item that is readily obtainable as on this boiler the value comes with a water filter (removable) The leak is actually coming from the isolation value itself, but only when under pressure, i.e. when filling system via filling line, rest of time no leak but clearly in need of attention.
3) The temperature of the hot water is not high enough. Having read through various material, including a lot of the posts here, a probable cause, and therefore 1st place to look, is the CH/DHW switch not activating sufficiently, and therefore insufficient water is diverting from CH to the DHW heat exchange - how can this be tested?
4) There is some evidence that there has been some internal leaking in the past, but not currently - there are 3 places of leakage evidence;
a) The aav
b) The prv
c) DHW expansion device connection (no device connected)
If I experience any future problems with the above could someone please advise if these items are readily available and replaceable.
Many thanks for any replies.
Paul
The symptoms where;
a) Fan starts
a) The aav
b) The prv
Paul
