I am having problems with our Alpha 240P combi boiler, the central heating is working fine however the hot water works only when the boiler has been on and is warmed up from the central heating.
If you turn the heating on and then open a hot water tap the boiler will go out. I have had a look at the valve positions, when the hot tap is opened the front valve actuates a pin and closes the contact on the solenoid. The back valve seems to stay open with the solenoid contact closed.
Once the heating has been on for 5-10 minutes the hot water works normally.
