Hi
My Alpha 240X is playing up. When you first turn on a HW tap, the boiler will ignite and heat the water. After a couple of minutes the gas goes off, and won't go back on until the water cools and you shut off the tap. Much the same with the Central heating.
I recently changed the thermocouple and made sure interrupter was properly seated.
I'm thinking the overheat thermostat, anything else I should be looking at?
