I haven't heard or read many positive comments about Alpha boilers but unfortunately I've recently bought an old 4 bedroom (high ceilings!) property that has one and so I'm stuck with it - for now. I have a problem with it and before I decide to look for a more reliable boiler I hope someone can point me in the right direction to sort out this one. I will need a reliable boiler for CH to maintain room temperature for a disabled child 24/7.
It is an Alpha 280P model (I think) and has been serviced by BG in the past. Quite often the burner doesn't light when the HW tap is opened and displays the flue/fan warning light - though it is temperamental. Have had the flue cleaned but still get the same problem. The CH tends to work if left on it's own and usually through a timer with no HW tap operated. The problem seems to arise when HW is required though on many occasions they both get along OK. When the burner doesn't light the fan does operate. I have tried switching off from the electric mains for a prolonged time (i.e. 30 minutes) and sometimes this helps but not always.
The Alpha manual seems to suggest the cause is a faulty fan or blocked flue but both seem to be OK. Could it be a faulty diverter valve?
Any help on the Alpha would be appreciated and advice on new efficent and reliable boiler welcome.
