Alpha Boiler - Intermittent hot water
15 Oct 2010
Lancashire
The hot water from my Alpha CD32C boiler is fluctuating between hot and cold, generally starting off hot then turning to cold. I have noticed that if i reduce the flow it seems to heat up again.
Any idea what this could be?
Thanks in advance
a) faulty Thermistor
b) Low Gas pressure/Rate - undersized gas pipe work
c) Scaled plate heat Exchanger
d) another as yet unidentified fault
