Hi, ive noticed that there is a very slow water leak from the return valve of my CB 28 Alpha Boiler. Do I need to replace this or is there a stop leak product I can use? The leak is coming our of the valve itself.
I'd replace the flow AND return ones - not expensive but they don't last well if used much. Leak stoppers might work but I'd only use for a leak I couldn't find.
