Can I have some advice from you good people.
I have a 4 1/2 year old Alpha C27. CH is fine but DHW is intermittant and when is works has a very low flow of 2.25 litres a min. I've read the other similar posts on here, and so checked the cold water inlet filter (completly clean) and had the DHW flow valve off which seems fine ( and does work intermitanlty ). Someone has offered the advice that it may be a 'scaled up heat exchanger' and I do live in a hard water area. The other posts mentioned a diaphram but I didn't see one when I had the flow switch off, and would that give a very low level of DHW.
Thanks for looking.
Don262
Thanks for looking.
Don262
