Problems startd off with shower not working properly - water started hot then went cold, came back hot and continued like this - most inconvenient to keep hopping in and out with soap in my eyes ! This was an intermittent problem because sometimes the hot water was fine.
Plumber replaced top temperature sensor.
Did not solve problem.
Then central heating started to play up - kept switching itself off but came back on when all radiators had gone cold. I have TRVs fitted on all rads except for 2 (one in bathroom and one on landing). When boiler cuts out - sometimes both red and yellow lights are on continuously, at other times the yellow light flashes on every second. Could not reset boiler until it had gone cold. Same problem as above with hot water.
Plumber replaced diverter valve. Seemed to be ok for 24 hours but.....
Now back to square one. Hot water sometimes comes on, sometimes it doesn't and sometimes it goes hot and cold. Central heating comes on, sometimes stays on for an hour goes off and resets itself, sometimes it stays on for longer.
Plumber coming back on Monday - any suggestions would be gratefully received - we need help. If you can't offer advice then please just pray for a warm weekend for me - but maybe not too warm if I can't have a shower!.
