Hi all,
We have an Alpha CB24 Combo boiler in our flat. Since we moved in, in May we haven't used the heating just used it for water which its fine. The pressure shows as about 0.6 bar which is in between the red and the green. However I turned the heating on and it dropped straight into the red zone so I turned it off immediately and it went back to its usual 0.6 bar.
Can I raise the pressure myself considering I don't have any plumbing experience or am I going to have to get a plumber?
Also this might be a bit silly but do combo boilers use thermostats as in the things on the wall where you set the temperature. We have two very old looking ones right next to each other in the hall but they don't seem to do anything.
Thanks.
Thanks.
