Hello All,
I have a seven year old Alpha CB24 with a leaking DHW Flow valve.
It is mains water that is seeping through the vertical joint in the Flow valve, joint to side plate (All systems working fine, pressure good, leak stops when mains water isolated).
Tray under boiler captured about a pint over-night! Lime scale deposits indicate that joint has been weeping for a while, but has now got bad.
My dilemma is what to buy in the way of a seal kit before starting. Kits readily available on internet (and only about £15), but look to come with different types/sizes of ‘O’ rings etc, depending on what kit you buy (even though they all come under the 3.013389 number?)
Or, having read posts on fitting kits, and possibly having to remove Flow valve (And DHW Heat exchanger etc…) to get access to side plate, would it be safer bet (but more costly) to put whole new assembly on, while all the bits are off?
Also if removing DHW exchanger for access, what seals/washers will need to be replace to ensure water-tight replacement?
If anyone can recommend a kit for this job, that would be great (even better if I could find it locally to Oxford, I’ve missed last post before Xmas today with some places).
Or, if I’m barking up the wrong tree, please let me know, thanks.
