Alpha CB24
19 Nov 2005
Hey Im so cold :p
I have an Alpha CB24 boiler and the pressure valve is at zero. Both the lights are flashing alternativatly which means(from the manual) that we need to repressure it. In the manual it says "Connec the filling loop between the connections provided. Open filling loop valves and allow needle to rush to green band."
Any1 got any ideas?
Thanks in advance, Simon
I have yes but i cant find anything. I have found the filling loop which has a little blue switch on, but i cannot find the valves??
Look directly underneath boiler, center pipe is mains in, valve to rear, loop fits to right , onto heating return.
I also have an alpha cb24 and directly under boiler there is a filling loop which has 2 valves on it,1 at each end of loop,i have to turn one half a turn to open loop and the other is pressured so i have to push and hold untill needle at required pressure,not sure if this helps..
just out of interest do you have a working room stat or does your boiler just run off stats on front panel???
