Hi, I need help! My boiler kept losing pressure to the hot water and needing topping up with the filling loop. I noticed it had been dripping, only a little, but getting worse.
I opened it up and it is dripping from a small hole under the flow switch, next to the diverter.
I have no problem with hot water or heating when it has pressure.
I removed the flow switch, had a small amount of black on the base, and refitted. Has maybe slowed the drip a bit, but maybe not, not sure.
Is this a flow switch problem or is it the diverter causing this? Could really use some advice, please ask if more info is needed!
