Alpha CB28 Fan or board fault?
5 Jun 2011
Aberdeenshire
Hello there, First time post but have found this forum very usefull in the past
I have a Alpha CB28 boiler that seems to have developed an intermittant fault.
Both LED's flash together which the manual says is a Flue or Fan fault.
I have had my multimeter on the fan supply at both the motor and board ends. The voltage readings are very irratic.... is this normal?
The fan does spin up when its asked for but occassionally after being run for a while it trips with both lights flashing. The fault resets its self if left idle and no water use.
Any suggestions how to identify if its truely a Fan on PCB fault?
A fan fault would need to be repaired by a registered repairer. With respect you should not be working inside the combustion chamber.Some basic checks of other components are required first.
I have no intention of trying to replace the fan myself, just trying to identify the fault as i can get parts at cost through a family member.
I respect your comment about not working inside the combustion chamber although I am confident about having the front panel off and carrying out visual inspections and multimeter checks.
Engineer paying us a visit tomorrow to carry out repair.
sorry dude but we can not give advice for parts inside the combustion seals as that could lead to major problems
