Alpha CB28 won't behave - I'm so cold...
2 Jan 2008
Tyne and Wear
Alpha CB28 had water diverted fitted two weeks ago.
Red and yellow lights on yesterday indicated a non running fan.
My plumber came out and pressed down on a relay on the board and the boiler kicked into life.
Coming home, and it's not firing up.
It now shows the usual yellow led every 5 seconds indicating its getting electrical feed, but all efforts to get it fire do nothing.
Any ideas please? Its freezing tonight, and I really want a bath.
Cheers, Lee
Looking at the service manual, it says pump runs and fan runs at max speed (yes) which I believe it does.
The next part of the check is air pressure switch proved? Am I checking the voltage across the switch?
Is it worth me trying a new PCB? It's not doing anything but the yellow B LED 5 seconds to indicate electrical supply.
Please help!
Cheers, Lee
