Now got 2 of these CB28 that are losing pressure regularly. Both about 3 /4 years old. No leaks any where on systems, prv tested and proved ok, pressure in system running normally between 1 bar and 2 bar, all hot water working fine as is ch. Apparently totally normal fully functioning boilers.
Do these Alphas have a 'common' problem where they can lose pressure internally somewhere without any visible signs to the eye
Any suggestions gratefully received
