Hello all
I'm having plenty of issues with our Alpha boiler, the lastest of which is lukewarm rads which I think is related to a temperature sensor.
The room stat demands heat and initially the burner will light though it turns off a couple of minutes later and the pump runs on as normal. I can get the burner to stay lit for longer if the CH stat on the boiler is turned up to maximum. With the boiler CH stat turned down to say 5 out of 9 the burner doesn't ignite until the flow pipe is cool to touch.
Hot water functioning normally.
I would hugely appreciate any pointers.
Thanks in advance
Steve
Thanks in advance
Steve
