My mum has just moved house, and her DHWater only heats up if the tap is turned full on (flow rate 7.5 litres/min). I've already replaced the diverter diaphragm, but that made little or no difference and the old one looked OK any way. I removed the differential pressure assembly to check the filter, and found the venturi part on the end was missing altogether.
I found the little coil spring when I removed the cold water inlet filter, but there was no sign of the rest of it. I have been trying to find a replacement part on-line (i.e. the whole assembly or just the venturi bit which screws in the end). UK-plumbing stock the hydraulic venturi assembly for the Baxi 105HE (part 248051), which I understand from other posts is basically the same boiler. Is anyone able to advise whether these parts are interchangeable, or if not, where I can get the pukka part for the Alpha please?
