Alpha Ocean 280e Overheat Thermostat light on
7 Dec 2013
Sussex
I recently replaced the DHW Flow Diaphragm to cure a leak and now the 'Overheat Thermostat Has Operated' red light is on and the boiler won't operate. The white reset button had no effect.
The fault finding chart suggests a problem either with the overheat thermostat itself or the neon PCB. Just seems strange that it has failed at the same time I replaced the diaphragm? Any thoughts on what could have happened and what the most likely cure?
Thanks.
