how easy is it to change dhw diaphram on an alpha cb24x.
nickso said:i do it by removing the plate h/e like dave.
i see no value in removing the pump as doing it that way usually leaves the other unions on the plate h/e leaking anyway.
oh yeh and, paul, you are a brave man to isolate an alpha with the F/R valves. dont think ive ever seen a set of them tampered with that dont leak .....even the ones left well alone will leak if you breathe on them.
