Since a plumber drained down my system to install some TRVs I am having problems getting air out of the system ( open vented, Worcester green star boiler)
The pump is making a rattling noise and I would to bleed it. However it is an Altech pump and does not have a slotted screw. It has a nut in the centre with as black plastic cover. I assume that to bleed it I need to unscrew the nut? Are you meant to use the cover to grip this with or remove it and use a spanner?
Any advice much appreciated.
cheers
cheers
