Hi all,
Upcoming kitchen re-fit will require moving some windows around - one window in the kitchen needs bricking up and another one needs slightly altering.
It's a small alteration - the current window is 1500mm wide x 1000mm tall. I'd like it reduced to 1100mm width - and I'm happy for the height to increase to maintain the window area if necessary.
Wall is solid brick and as far as I can tell the concrete lintel is a false lintel with just the bricks underneath.
I'm aware window installation has to be by a FENSA installer so I'll be getting the job done professionally. But what I can't work out is whether I need building regs approval for altering the window opening, or can I just let the builder get on with it?
Thanks,
Thanks,
