We are currently carrying out a loft conversion of our home and will need to add two new radiators to the system for the new rooms in the loft. I have read other posts on DIYnot and understand how to work out if our existing boiler will take the extra load but have a couple of other queries relating to this.
We have a Worcester Bosch 28CDi combi boiler. I will need to drain the system to carryout the new work and understand i should turn the boiler off. Can i still use the boiler for hot water while the central heating system is drained or should i leave the boiler completely off until the heating system is re-filled.
When i re-fill the system, how do i calculate how much inhibitor to put in? Our existing system consists of two large single radiators on the ground floor. 1 medium and 2 small single rads on the first floor together with a small double rad in the bathroom and i intend to install two medium single rads in the loft. One of the large ground floor rads may also be downsized.
Any advice will be gratefully received.
