Altering room divider
15 Apr 2016
First post here so apologies if this is in the wrong forum.
I have a stud partition divider between my living room and dining room. It's basically an open archway much like you might see in many houses. So there are two sides and an arch over the top and then there is coving around the ceiling.
I would like to try and open this up a bit without actually removing the whole partition as I don't really want to repair a hole in the wooden floor and re-plaster the ceiling. My thought is to cut the sides off at around the height of the sofa arms and then cut the top off leaving a small beam across the ceiling. So basically from the height of the sofa up to as high to the ceiling as I dare go the whole thing would just be cut away.
My two questions are: What would be the best tools to do the cutting and make sure it's a nice clean straight cut and also what would this do to the stability to the wooden beams underneath, would it just ruin the whole partition or would it be fine?
Thanks for any advice.
