Hello.
We are installing a new shower in our bathroom (hot & cold gravity-fed) with a pump that will be fitted in the loft / airing cupboard. The previous shower was a powered shower (white box on the wall, cold water feed only) with its own power supply rated at 45A from consumer unit downstairs.
I have removed the old shower and pulled back the cable into the loft. I would like to terminate this cable with a fused connection unit next to the pump. Am I right in thinking that as long as I fuse down correctly at the point where the cable size changes I can use the old power supply for the new pump? Should I leave the 45A fuse in the Consumer Unit, or should that be changed?
I do not want to pull out the old cable as it would wreck the decoration! Also it appears to be in good condition, and as I am effectively over-speccing for the pump I don't think this should be a problem. Is this correct?
Many thanks.
Many thanks.
