Hi folks
I'm about to move into a new build house and the builders have put run a feed from the house consumer unit to a smaller one in the detached garage with RCD on the light and socket circuits. The garage is 6Mx6M and now has a single socket and a single pendant. Before I get a sparky in to advise on the job I thought I'd pick some brains here.
What I actually want in the garage is 6 double sockets, 10 LED spotlights (ceiling going to be boarded to look nice), power for electric garage door opener, PIR controlled wall lights (LED) on garage entrance and some soffit LED down lights probably also PIR controlled.
I suspect the garage may get damp so think the new consumer unit should be IP 65 rated. I'd also be interested in using rcbo to give independent protection on every circuit. I realise it's probably overkill for what I need now, but it will hopefully give some options for future expansion too (depending on how things are wired to the house CU and size of cable that was used to connect the garage)
Has anyone done a similar install? If so what would be approx cost and which consumer unit did you use that was big enough for the rcbos and still have decent room to get the wires in
Regards to all
Paul
Regards to all
Paul
